light fingered fred's about
Post by WideOpenThrottle » Mon Feb 27, 2012 2:05 pm
Would you believe it!..while my engines been at the shop my cas,coil pack,both cam gears,crank-pulley/sprocket,cam cover,themostat & housings plus both water sensors, alternator & bracket, all the front timing covers,one engine mount & bracket,rear main seal flange,water pump pulley & inlet tube plus intercooler have all mysteriously disappeared from my garage bench awaiting re-fitting! :(
All the parts needed [mostly] to convert a distributor set-up to a Cam angle system on a familia or gtx or similar.
Be on your toes & i hope it never happens to you!
Post by biff » Mon Feb 27, 2012 2:46 pm
Hells teeth, this your garage at home?
I'd be looking hard at those who knew the gear was there!
(Then shoot them)
Biff
Red 90
From: WideOpenThrottle [mailto:mx5talk@mx5forum.co.nz]
Sent: Monday, 27 February 2012 2:06 p.m.
To: mx5talk@mx5forum.co.nz
Subject: [MX5] light fingered fred's about
89 project mx5
http://www.mx5forum.co.nz/viewtopic.php?p=48262#48262
Post by WideOpenThrottle » Mon Feb 27, 2012 2:59 pm
Yep this is my secluded home fully locked garage & i have my suspicions!
Someone definately knows the system around here!
You just cant trust A-N-Y-O-N-E
light fingered Fred's about
Post by biff » Mon Feb 27, 2012 3:09 pm
I have a FBG if ya need it :)
Biff
Sent: Monday, 27 February 2012 3:00 p.m.
Subject: [MX5] Re: light fingered fred's about
89 project mx5
http://www.mx5forum.co.nz/viewtopic.php?p=48264#48264
Post by WideOpenThrottle » Mon Feb 27, 2012 4:14 pm
Ta but the FBG would be too quick & painless so maybe a slow self tightening noose around the testicular region would be better for the shi!!!!!!! :D
Post by brownie » Fri Mar 02, 2012 9:27 pm
I have a long nose crank engine coming back to me at work(Mazline) as a exchange unit,If you get stuck i will be able to sort a deal on what you need if you have no luck finding your bit's or anything else local.
Post by WideOpenThrottle » Mon Mar 05, 2012 7:13 pm
Hi brownie
Did you get my pm?
Gary
Post by brownie » Mon Mar 05, 2012 10:04 pm
Yea just found it,i will start looking at work tomorrow and get in touch
