1.8l front brake caliper brackets
RMS
Post by RMS » Tue Jan 10, 2012 12:27 pm
I'm looking for a pair of front caliper brackets from a 1.8l model MX5 in order to upgrade the brakes on my MX5.
Does anyone have a spare set they will sell?
Post by WideOpenThrottle » Tue Jan 10, 2012 8:22 pm
Tried - Ross at MX5mart?
2low2c
Post by 2low2c » Tue Jan 10, 2012 9:47 pm
i have a complete set of nb 1800 front brakes ,callipers,discs and pads .if your intrseted pm me
RMS
Post by RMS » Thu Jan 12, 2012 10:10 am
I emailed Ross but I guess he's on holiday, had to get the car moving in a hurry so I've just thrown some stock 1.6 rotors and pads on instead, brake upgrade will have to wait
thebears
Post by thebears » Thu Jan 12, 2012 11:39 am
RMS wrote:I emailed Ross but I guess he's on holiday, had to get the car moving in a hurry so I've just thrown some stock 1.6 rotors and pads on instead, brake upgrade will have to wait
I ordered off Ross this week, guess he is busy.
Post by Mad Kiwi » Mon Feb 13, 2012 6:25 pm
I just collected mine today, anyone done this and can report the difference or imprvement (i HOPE it is an improvement....)
Post by WideOpenThrottle » Mon Feb 13, 2012 8:25 pm
Certainly improved mine-but then i have race pads too!
Mikkels
Post by Mikkels » Mon Feb 13, 2012 9:40 pm
I have done the upgrade and brakes are definitely more authoritative. What went wrong for me was that I had brand new caliper mounts so needed to remove the rubber insert for the lower caliper pin. I managed after a lot of sweat. The process that succeeded for me was to use a thin piece of stiff wire to guide down the side of the insert then work right around with CRC to lube it all. Can then pull out by gripping the closed end while pushing the open end through. Also be sure to install springs on the pads. If you do not you will have an annoying rattle from the pads.
I did not have any springs and ended up getting some from Pick a Part and modifying to fit. BTW if you destroy the rubber inserts the ones on old 323 lasers are the same. Ready supply at Pick a Part.
Have fun.
If you are in Auckland i can help if you need it
Don
Post by Mad Kiwi » Wed Feb 15, 2012 5:12 pm
Just installed mine too, definately feels better, haven't done any full hard stops yet but I from my quick drive it feels..... well "authoratitive" ....is a great description :lol:
Looking forward to a fang and seeing how they hold up.....
Mikkels
Post by Mikkels » Wed Feb 15, 2012 9:19 pm
Good job. Did you have springs for the pads?
Mine did not rattle right away but later on got very rattly and I took a while to figure the source of the rattle.
Enjoy the stopping power.
Don
Post by Angreal » Fri Feb 24, 2012 9:01 pm
Mikkels wrote:Also be sure to install springs on the pads. If you do not you will have an annoying rattle from the pads.
I have the annoying rattle and I don't have the springs on any of my brake pads. Where do I go to get a set of springs and how do I make them fit?
Post by brownie » Fri Feb 24, 2012 10:12 pm
Not really springs as opposed to wire clips,Rears have "w" clips ,top and bottom ,Cant remember the front ,but usually its the rears that go missing anyway..
They also have tin shims on the calipers as well,The 1600cc and 1800cc shims are slightly different,So you need make sure the upgrade kits come with all these as well.
