Auto & Manual engines
Hi
Does anybody know for sure if the NA 1600 Auto engines as found in NZ are the lower HP ones with a milder cam?
According to some US sites they are!-[ between 1989-1993].
Most wreckers/dealers i have talked to in NZ have never heard of this difference.
As i am now needing a replacement engine rather than a re-build & i sure would like to have some clarification on this as it may have some bearing on being turbo'd & possible shortcomings?
So do you think that they lose power/torque at high rpm earlier than the manual engine or much the same?punkoutnz wrote:Yes I believe they are. However my car was originally an automatic and I think if anything, the auto engine will be even better with a turbo bolted onto it. Mine certainly has a huge whack of down low torque! Even off boost...
the auto engine will alow "more boost" but it won't make any more power at that boost because it is a less efficient engine, and will only flow the same volume of air at the higher boost level as the high CR engine at a lower boost level.
the lower compression will only give you a wider window to tune in before knock sets in. And with todays modern ECU's theres no point.
even if going turbo , get a normal engine and enjoy the benefits of better economy and throttle response.
as ive said before the #1 limit to how much HP you can make with a 1600 is the strength of the conrods. and both manual and auto share the rods anyway..
you can bolt on a BMW 318 tps sensor in place of the mx5 one if you need a variable TPS for an after market ECU.
