Strange squeal
mikey
Strange squeal
Post by mikey » Thu May 18, 2006 8:56 pm
Been getting a strange squeal from the engine bay whilst sitting in traffic and idling at lights....
Yes, have changed the belts very recently... no slippage... so they are out...
Was told by someone that it may be the alternator's bearings.. the car has done 180+k's...
Can anyone advise?
simple
Strange squeal
Post by simple » Fri May 19, 2006 10:32 am
My car had a squeal once - in my case it was a clutch problem. If your
car is one of those funny ones without a clutch pedal, then you should
definitely consider other possibilities... :-)
Karl.
[Posted via External Email]
Shift4Brains
Re: Strange squeal
Post by Shift4Brains » Fri May 19, 2006 12:51 pm
mikey wrote:Been getting a strange squeal from the engine bay whilst sitting in traffic and idling at lights....
Can anyone advise?
It probably will be the belts . I usually test by squirting some water onto the belts, if the noise goes away (temporarily) then the belts are causing the noise.
