Another RX7 AFM thread...
I know there are dozens of RX7 AFM threads around, but reading them all only deepens my confusification.
I have a S4 RX7 AFM. I want to put it in the Mazdarati, preferably with a reliable, step-by-step guide. I know that it plugs into the factory loom, and I know you have to fiddle around with the vane spring tension, but how many clicks is the ideal? and how will I know if the car is running lean at WOT? What other pitfalls are there in this mod?
Any clarification is really appreciated.
Zac
Zac
Roses are red
Violets are red
Trees are red
Oh fuck, my garden's on fire
Violets are red
Trees are red
It made a big difference up top on my motor with mild cams.
I ran a wire from the oxy sensor into the car and hooked a multimeter onto it. Checked the voltage with stock AFM at full throttle and then adjusted the RX7 to match (actually made it a little leaner as the stock AFM looked rich)
Pitfalls? Not much really. Cold start is a bit rougher and prob a bit less power below 2000rpm. But my other mods dont help this and its not major
