Compression test?
Compression test?
I would like to get my NA,s engine compression tested as i suspect that it may have a problem, its goes good and starts fine but very rarely it blows a bit of smoke. Not all the time but I would like to get it checked out. My question is does anyone have a compression tester I could use to check it or where can I get this done? Will most garages have a tester? Any help would be great.
my long range diagnosis is valve stem seals....
my cars seals arent the best and it smokes just a bit about one in 5 starts or so...
i suspect that it was caused by me when i put the turbo on and i didnt tune the light load fuelling quite right...it was a bit lean and i suspect the exhaust gas temp went too high cooking the exhaust valve stem seals....oh well still goes like snot so who cares!
