MX5 2004 MODEL - Reverberation of steering on slow full turn
BISCUIT100
Post by BISCUIT100 » Wed Jul 06, 2011 9:52 am
Hi recently purchased a 2004 mx5 and having problems with a steering reverberation when turning hard to full lock left or right. It makes a shuddering noise when in the last 5 degrees of full lock on the turn ? The hydraulic pump makes a slight noise at this point of a tight slow turn. :o
mazline
Post by mazline » Fri Jul 08, 2011 5:14 pm
power steer pump might be dicky
Trevor
Re: MX5 2004 MODEL - Reverberation of steering on slow full
Post by Trevor » Fri Jul 08, 2011 6:40 pm
BISCUIT100 wrote:Hi recently purchased a 2004 mx5 and having problems with a steering reverberation when turning hard to full lock left or right. It makes a shuddering noise when in the last 5 degrees of full lock on the turn ? The hydraulic pump makes a slight noise at this point of a tight slow turn. :o
Air in the hydraulic system causing a valve to chatter can result in this sort of problem..
Trevor.
