I have one inlet valve on #1 down to 0 clearance, ALL others are normal, exhaust also normal. I have a bad cold misfire which reduces to minor when warm. Nothing else is faulty, been through everything. Just #1 compression down to 150.
This suddenly started a few weeks ago, engine was fine before then.
It is a JDM 98NB 1600 with solid lifters, the shims are all similar thicknesses.
Have I dodged dropping a valve? and the stem has stretched??
I've posted in the Miata forum also.
Anyone had an inlet valve clearance sudenly drop to ZERO
The head is at the doctors to have a new valve fitted and re-shimmed. He will replace all 16 guide seals and fit new cam seals also.
Pix on the Miata.net forum http://forum.miata.net/vb/showthread.php?t=426120
