4 wire O2 Sensor
4 wire O2 Sensor
Is there anyone out there have a set of instructions for fitting a 4 wire o2 sensor on a 91 NA6? Currently have stainless extractors with the standard single wire o2 sensor.
Also, can anyone advice on a suitable o2 sensor to install?
4 wire O2 Sensor
google "miata o2 sensor 4 wire conversion" :]
It'll screw right into the same bung... maybe pick up one from a wreckers to practise on first (wiring-wise)
you can also use a 3 wire one.
i have a 3 wire in my car.
generally speaking they have two colours of wires. usually they are black and white, two will be the same colour and one different.the two the same are the heater and the third is the o2 signal wire. heater polarity not usually important
I think this is why my car appears to run rich. Just wondering but what's involved in getting an a/f gauge installed as well as a heated o2 sensor? I'm thinking something like this but any advice would be appreciated http://www.innovatemotorsports.com/products/MTXL.php
Users browsing this forum: No registered users and 70 guests
