Springs and shocks for a NA
I am after lowered springs and new shocks for my NA. Any help/advice would be great....which brand to buy? where to buy? etc...... Cheers
here are a second hand set of damper adjustable shocks
not adjustable platform so no need for certification
http://www.trademe.co.nz/Trade-Me-Motor ... 741876.htm
this may help if you want to get anything certed
http://www.mx5forum.co.nz/garage.php?mo ... ness_id=45
The standard boots incorporate the bump stop however if you want to go to aftermarket bumpstops you will need to check what the fully compressed travel of the shock and spring is as you don't want to end up with coil bind or with your nice new shocks bottoming. Stocks can also supply bump stops.
You may also find that you need some spacers on the top of the shock body to ensure that your bump stops are working at the right point. These normally come in 3mm thicknesses.
For the boots I found some Subaru steering rack boots that do the job, but I am using Konis. They may also fit the shaft size of the KYB as I had to cut out the narrow end to fit the top of the shock.
