Interesting what i just read on the miata net turbo installation proceedure!
Don’t use header wrap, as it causes the manifold to crack. Using header wrap will void your warranty.
I assume they mean the asbestos bandage?
Heat wrap
Heat wrap
Heat wrap
Actually its at flyin miata
http://www.flyinmiata.com/support/instr ... turbos.pdf
just in case someone wants to read it
Re: Heat wrap
Stainless steel and cast iron will crack when bandy'd if given a bit of heated, prolonged, fun driving, you can however wrap mild steel, just make sure you use a suitable anti rust coating before the wrapture .
Oh well I have said all I need to say on the subject,so I guess thats a"wrap".
