johngalt
by johngalt » Mon Apr 26, 2010 6:16 pm
What have I done? twice now I have stopped the car and taken the key out and then straight away replaced the key and tried to start the car, all that happens is it turns over but doesnt fire and a light under the speedo flashes on and off. I take the key out and leave it for ten minutes and then it starts like normal.
any questions or ideas, let me know. cheers
1993 NA 1800 red MX-5
Gravelben
by Gravelben » Mon Apr 26, 2010 7:47 pm
Does it have an alarm/immobiliser in it? Some alarms have a strange 'anti-carjacking' feature that can do odd things like that.
johngalt
by johngalt » Mon Apr 26, 2010 7:56 pm
Yup it does, a uniden alarm /immobiliser.
Thats the first thing i thought of but reset the alarm twice and it didnt help, also weird with the dash light flashing on and off.
Gravelben
by Gravelben » Mon Apr 26, 2010 8:07 pm
Yeah fair point, you'd expect the alarm warning light to do that instead if it was the alarm (and assuming it has a warning light). Is the flashing light any distinctive shape?
johngalt
by johngalt » Mon Apr 26, 2010 8:19 pm
there are two lights under the speedo, one for the lights going up and one for the hold button for the auto.
blackbetty
by blackbetty » Mon Apr 26, 2010 9:22 pm
when alarm guys program a new remote they do some strange on off on off with the key then press the remote button and things like that.you may be doing half of something like that or an immobiliser code or something by mistake
"What's the driving force behind blackbetty"........Satan
:twisted::twisted:
broomfish
by broomfish » Mon Apr 26, 2010 9:31 pm
which light is it that is flashing?
johngalt
by johngalt » Mon Apr 26, 2010 9:42 pm
auto hold light
broomfish
by broomfish » Mon Apr 26, 2010 10:31 pm
That light flashing is an indication of a fault. When i inadvertantly started my NA8 without any trans fluid in it the light flashed to tell me i was a dork.
This info is from forum.miata.net
The HOLD light flashes a code similar to the Check Engine Light. You can cancel the codes from memory by removing the negative battery cable for at least 20 seconds and pressing the brake pedal. You might want to try doing that first.
To pull the code, connect the TAT and GND terminals in the data link connector with a jumper. Turn on the ignition, and the transmission control module flashes the Hold light with the code. The codes are 2-digit and are as follows for the 95 (I assume the 94 is the same):
06 - Vehicle speed sensor or circuit
12 - Throttle position sensor or circuit
55 - Input/turbine speed sensor or circuit
60 - Shift solenoid A or circuit
61 - Shift solenoid B or circuit
62 - Shift solenoid C or circuit
63 - Torque converter clutch control solenoid valve or circuit
62 - 3-2 control solenoid valve or circuit
johngalt
by johngalt » Tue Apr 27, 2010 8:56 am
thats great thanks heaps peter, did you also have the car not starting aswell ?
broomfish
by broomfish » Tue Apr 27, 2010 8:59 am
no my started and ran fine, just didnt move
johngalt
by johngalt » Tue Apr 27, 2010 10:53 am
hey Peter, I'm a bit thick
when you say 2 digit code does that mean for 12 as an example it flashes once pause then twice and stops or repeats. cheers
