Cam angle sensor failure
tonysuesmith
Post by tonysuesmith » Wed Feb 03, 2010 8:17 am
if electrical analysis module says cam angle sensor failed, but after changing it to a good one, the fault stays. No spark, no pulse to injectors
Any ideas?
Post by Habanero666 » Wed Feb 03, 2010 8:25 am
what model year and engine type?
Post by sprsta » Wed Feb 03, 2010 7:00 pm
yes some more details would help.
i would start by checking the power and ground
Ben.Nakagawa
Post by Ben.Nakagawa » Thu Feb 04, 2010 7:55 am
loose ignition wire? May be just double check and reseated...
Ben
Post by sprsta » Thu Feb 04, 2010 9:09 pm
might help you withiut any more info
http://www.miata.net/garage/ECU_Pin-Out.png
