what is the best aftermarket windblocker?
johngalt
Post by johngalt » Tue Dec 29, 2009 10:18 am
I have the one that fits on the headrests and its not very good with the bonus of being ugly :lol:
1993 NA 1800 red MX-5
ham
Post by ham » Tue Dec 29, 2009 2:15 pm
I made a template of the shape i wanted and had a friend cut it out of 10mm glass and toughen. Then slipped it into a piece of aluminium channel each side. with rubber window strips to hold it tight. Can be slipped out in under aminute if desired. Utilised existing bolt holes each side. Others have done similar using 10mm pespex. Don't like the ones from MX5 mart as tend to rattle around in the breeze if seats not pushed hard back. Hope this helps.
1989 NA Blue JRSC.
DBM58
Post by DBM58 » Tue Dec 29, 2009 2:55 pm
I have one made up in this style out of a perspex-type material - I'm not
sure if it is perspex, polycarbonate, Lexan or something else. You are most
welcome to borrow it to try it out. I am in Royal Oak, Auckland.
David
johngalt
Post by johngalt » Tue Dec 29, 2009 9:28 pm
did you go the full height? as the mx5mart ones look abit low.
Thanks for the offer David but im in chch. cheers
Paul Murray
Post by Paul Murray » Wed Dec 30, 2009 8:44 am
John, the previous owner of my car and David's produced a perspex windblocker that fits between the stylebar and is held in place with velcro ties. Easily removeable. I remember how well the windblocker reduced the draft to the back of the neck and head. I am sure Matt who previously owned our cars wouldn't mind you taking a look at his cardomain site www.cardomain.com/ride/241633/3
I checked it out this morning and it is still up and running
DBM58
What is the best aftermarket windblocker?
Post by DBM58 » Wed Dec 30, 2009 9:43 am
Mine is slightly different in that it fits in front of the style-bar and runs the full (internal) width of the car. It is only held in place by gravity really - and the fact that it is located by sliding in to channel screwed to the car at each end.
Windblocker
David
johngalt
Post by johngalt » Wed Dec 30, 2009 10:19 am
Thanks guys, they look great. I am going to make up a template and get one cut out for me. I have the full style bar and wonder if i should fill the whole thing in?
Post by SLYDIT » Wed Dec 30, 2009 2:24 pm
you don't need to do all the way up. its a law of diminishing returns. you are trying to stop the air coming in from the back and not the air over the top of the car front to back. up to the top of the seats is plenty tall enough.
johngalt
Post by johngalt » Wed Dec 30, 2009 8:19 pm
Hmm that is about the same height, I think it will look abit weird going half way up the style bar.
http://images.trademe.co.nz/photoserver ... 6_full.jpg :?
Paul Murray
Post by Paul Murray » Wed Dec 30, 2009 8:50 pm
David, apologies for assuming Matt had sold you the car with the same windblocker he had manufactured for mine.
DBM58
Post by DBM58 » Wed Dec 30, 2009 9:07 pm
No worries at all. In truth, on the day we swapped cars we pu the two next
to each other and pulled them apart and put them back together agian with
the bits we each wanted to keep. Thnaks for the thought though.
David
Post by Timmo » Wed Jan 06, 2010 3:25 pm
A roof! :roll:
johngalt
Post by johngalt » Wed Jan 06, 2010 4:51 pm
:lol: yup stops the sunburn too.......
Gravelben
Post by Gravelben » Thu Jan 07, 2010 12:54 pm
I have an MX5mart windblocker, but instead of using the flimsy upholstery plugs it came with to mount it I used bolts and big flat washers which holds it much more solidly.
Ben.Nakagawa
Post by Ben.Nakagawa » Thu Jan 07, 2010 7:32 pm
Gravelben wrote:I have an MX5mart windblocker, but instead of using the flimsy upholstery plugs it came with to mount it I used bolts and big flat washers which holds it much more solidly.
I have same idea. Could you share what size bolt you have used?
At moment I have those nylon archer and metal screw with large washer. Not quite steady enough for my liking, as the nylon archer is not quite right size. But it's better than that large carpet clip.
Wind broker is working reasonably well, I haven't tried another so I can not compare, ...but... from the no blockers, it's totally different.
Ben
Gravelben
Post by Gravelben » Mon Jan 18, 2010 11:57 pm
I forget what size bolt sorry - I think they were leftovers from a tardme shortshift kit I bought and then removed after the bushings fell apart, but I might have drilled the existing holes out slightly to fit them.
Sorry if thats not much help, best way is probably just to pop one of the plugs out and try a selection of bolts to see what fits the same hole.
