NB Door speakers
NB Door speakers
Post by poison » Thu Dec 03, 2009 12:39 am
Anyone upgraded their NB door speakers?
There seem to be a lot of direct 5x7/6x8 replacements her in NZ. But looking on USA forums a lot of guys used a Clearwater brand 8" (Too expensive to bring here).
An 8" would have to be really shallow. You can also get 8" to 6.5" adapters, but again not here.
Experience anyone...
Grant
NB Door speakers
Post by Grant » Thu Dec 03, 2009 7:53 am
I replaced my Bose door speakers when I removed the Bose system in my NB. It
was awful! There is a lot of room in the doors. I used 8" subwoofers that
Supercheap had at the time. They were easy to fit as the hole spacing
matched and although quite deep, there was still plenty of clearance. I
still used the original tweeters but had to add attenuation.
I was going to make some spacers from marine ply to allow fitting of 6.5"
speakers. This would have been simple to do but I liked the idea of getting
the full 8" cone size.
I was told at the time that Pioneer had some good 8" speakers but couldn't
find any here.
Grant
NB Door speakers
Post by Grant » Thu Dec 03, 2009 7:57 am
Should have added I replaced the Bose radio and bypassed the Bose amplifier.
I installed a JVC mp3 capable unit. Results were excellent and far better
than the Bose original.
The car was an import 1998 V-spec.
NB Door speakers
Post by poison » Thu Dec 03, 2009 11:36 pm
Hi Grant, Mine is not the Bose system, I assume they both have the same door
panel cut-out. Mine have a plastic adapter so they can use the 5x7 series,
just about everyone makes them. I'll have to pull the door off again and
confirm the cut-out size, must be 8" although the plastic adapter is under8"
across.... confusing.
