soulfader
by soulfader » Tue Oct 27, 2009 7:16 pm
mine finally doesnt work anymore...
can anyone recommend me a good place to buy one? good place as good price
i will probably get a low profile one this time to save me hassles
JiB
by JiB » Tue Oct 27, 2009 10:22 pm
I use a Wayco SuperLow, very reliable, just low enough to get under the race car ~90mm. Can highly highly recommend. Bought for $190+gst, unsure of retail.
http://www.wayco.co.nz/w1001.htm
Have a standard 2.5 tonne Wayco at the workshop that fits under my roadster (standard height) just fine. Unsure of price.
http://www.wayco.co.nz/w1000.htm
Otherwise try AES in Westhaven, they have sharp pricing with all sorts of tools. Really good guys to deal with too
That's where I'd go if I needed a jack.
Hope that helps
KSCRIM
by KSCRIM » Wed Oct 28, 2009 7:36 am
For scissor jacks, local wreckers are the best source, otherwise try Repco or Supercheap.
by Euen » Sun Nov 01, 2009 10:00 pm
I have been using this one from Savebarn
http://www.trademe.co.nz/Trade-Me-Motor ... 647150.htm
They are quite low and will get under a 5 with no problem. They are a bit short though so you are better off jacking from the side rather than trying to get under the diff or front subframe.
They normally list for about $240-245 incl GST. Only problem I have had is pump seals went on my first one after a year of quite heavy use.
The seals seem to be a problem on the Chinese race jacks. I also had a bigger version with longer reach under the car and the ram seals went on that. I had it repaired but the new seals failed as well and the cost of the repair compared to the cost of a new one made further attempts uneconomic.
If you are thinking of buying one of the Chinese ones then check what the warranty is on it.
soulfader
by soulfader » Mon Nov 02, 2009 6:26 pm
190+gst is good price.. i have been asking around and looks like its around 400 to 500 mark
might be too much for me
