tauranga mechanic recommendations
Psycho_Dad
Post by Psycho_Dad » Sun Mar 29, 2009 8:50 pm
well i just did an engine conversion on my car, its idling, but when i rev it its a pig, ive changed injectors(fact for fact) factory computer, fuel filter(which was pretty blocked) and its still running like junk
i just wanna tow it to a mechanic who knows their stuff and can trouble shoot better than me, because im lost for words
and it has to be in tauranga because im not towing it furthur
cheers for the suggestion
Psycho_Dad
Post by zorruno » Mon Mar 30, 2009 2:48 pm
timing?
Post by jif » Mon Mar 30, 2009 2:55 pm
... or ignition cables?
Post by Growler » Mon Mar 30, 2009 5:20 pm
What did you change? The whole engine?
Have you checked there are no leaks in the pipework to the inlet manifold?
2low2c
Post by 2low2c » Mon Mar 30, 2009 6:26 pm
Check the plug on the air flow meter ,also check the hose from the idle control vale to the main intake pipe
Psycho_Dad
Post by Psycho_Dad » Mon Mar 30, 2009 6:58 pm
swapped the whole engine, minus the inlet butterfly
cleaned airflow meter plug with contact cleaner
timings at 12 degrees
pressurised inlet manifold, its allmost holding 7psi(leaking through injectors, not enough to make such a problem)
blocked idle control valve lines and it still does it
swapped ignition cables
the new engine was running a link though, could that have anything to do with anything
im really out of ideas here guys, mechanic is the next option
it wont idle at 12degrees for very long
peace
Psycho_Dad
Post by WideOpenThrottle » Mon Mar 30, 2009 7:48 pm
Oxygen sensor or maybe overlapping ignition cables-water in sparkplug sockets or shorting to earth via carbon deposits in hole or maybe dirty fuel jets
Post by WideOpenThrottle » Mon Mar 30, 2009 7:57 pm
Mmmmmm maybe reset your ECU? have you good spark?fuel at the injectors-fuel pump ok?Was the new engine ok prior to swapping?
Psycho_Dad
Post by Psycho_Dad » Mon Mar 30, 2009 11:04 pm
spark seems good, tested each sparkplug out of their holes, ill check the overlapping oxy sensor in the morning, ive replaced the ignitors just in case, and the injectors incase they were blocked
fuel pressure is their, tested with a fuel guage on the rail, and fuel pressure reg is working correctly, talk about head fck
ecu has been reset, and swapped for another ecu just in case, no error codes, new engine had done 60,000kms, i didnt swap the cambelt, just put her in
it out of my league it seems
PSycho_Dad
Psycho_Dad
Post by Psycho_Dad » Sat Apr 11, 2009 9:24 pm
just for an update, got it back from tauranga auto electric, they said airflow meter, best $250 ive spent
except ofcourse its still running like this
http://www.youtube.com/watch?v=1Vcn89Eq ... annel_page
the youtube one isnt my car but sounds exactly like a bridgeport rotary
http://forum.miata.net/vb/showthread.ph ... ge=1&pp=25
thats how he fixed the problem, but ive checked the wires running from the afm to the ecu and the tps to the ecu and they seem to be dandy(since he ran the wrong red wire)
it running really rich as it is, cam belt timing is fine, according to the prev owner the engine was running sweet
more ideas or suggestions as usual would be appreciated
oh btw if i retard the timing to below 8 degrees it seems to stop running rich, could it have something to do with where the cas is set? is the cog adjustable?
PEace
Sam
Post by sprsta » Sat Apr 11, 2009 9:28 pm
what are you getting from your o2 sensor that may be telling the ecu that its running lean and dumping a crap load of fuel in
Users browsing this forum: No registered users and 60 guests
