Finished tuning....at long last!
Post by Habanero666 » Fri Feb 27, 2009 1:48 am
Finished all I can possibly achieve ( power wise ).
Heres my tune,
TD04H 15g Turbo with TurboSmart MBC running 16 PSI
Custom Dual exit DP
550cc Mazda Cosmo injectors ( purple tops )
Stock fuel pump and fuel lines.
Rewired Flyin Miata Link mark I ECU with latest software and air temp and Knock sensors also mark II map sensor
Mitsi evo 5 BOV
Nissan 200sx Front mount intercooler with DYI plumbing and Corky Bell air dam
Simota pod filter with cold air routing
Madaz BFMR B6T Rods
ACL race series bearings
Port and polished head and re-profiled combustion chambers
Special head gasket
Revised Cam profiles
Stock valve springs with oversized valves and seats
Ridiculously lightened fly wheel ( thanks CSL NZ Awesome job! )
HD clutch kit
2.5" exhaust with Trust rear silencer.
I will have to dyno this set up. It might be interesting!
How many STi's have you eaten lately? :wink:
cappo1
Post by cappo1 » Fri Feb 27, 2009 7:09 am
Well done top effort, when is the Dyno run?
Cappo1
last_resort14
Post by last_resort14 » Fri Feb 27, 2009 5:14 pm
yes, when is this run?
it will be really good to see what you achieve.
Post by Habanero666 » Sat Feb 28, 2009 7:58 am
Gonna book it in on thursday next week here in Palmy :D
cappo1
Post by cappo1 » Sat Feb 28, 2009 2:18 pm
Hi , reading your list of hardware i see you have the early Link ECU with the latest FM chip etc.
With your tune do you have a set of printable or emailable settings for the fuel and timing settings ?
I have an early Link that needs adjusting, the reload settings seem worse than the original seettings when i got the car, so I am looking for the data as a base line setings, that is some one peplies to my wanted add for a hand controller .
thanks
:D :D
link tuning
Post by jif » Sat Feb 28, 2009 3:56 pm
Hi Cappo1
I could help with a few pointers for the Link if u like - a wideband is super useful. The FMLink tuning manual is also quite good, as are their rich and retarded defaults (ie safe)
I'll see if the guy who bought mine wants to part with the handcontroller or serial box.. dont think he even touches them!
-J
cappo1
Post by cappo1 » Sun Mar 01, 2009 8:20 pm
Hi Jif ,that would be great ,let me know if your buyer is interested.
I will have a chat when we catch up re the bumper.
cappo1
Post by cappo1 » Mon Mar 02, 2009 6:54 am
Hi Jif, Do you have a economic fix to the wide band?
or anyone else out there cappo1
Re: Finished tuning....at long last!
Post by Growler » Mon Mar 02, 2009 1:56 pm
Habanero666 wrote:Finished all I can possibly achieve ( power wise ).
Heres my tune,
Custom Dual exit DP
Mitsi evo 5 BOV
Madaz BFMR B6T Rods
Special head gasket
HD clutch kit
Have you taken photos of what you did to the combustion chambers etc?
What lift etc have you used for the cams and are you using standard lifters or solid lifters?
Having a look at what you did to the ports would be good too!
Re pics
Post by Habanero666 » Tue Mar 03, 2009 12:38 pm
Hi there Growler, sorry no pics. I am not going to release the cam profile specs, but you can well imagine they are low overlap. I am using new hydraulic lifters. Sorry to be secretive!
