who has a cheap clutch for sale na6c
i got made redundant a week ago, just as i was about to chuck a 70,000 km 1.6 in my car, i have a feeling my clutch will need replacing, just wondering if someone has a hd clutch theyve pulled out of their wreck and storing for someone like me to take off their hands
oem from partsmaster will cost me 258
any suggestions would be appreciated, and offers even moreso
Psycho_Dad
Psycho_Dad
As long as you have a flywheel an 1800 pop's right in. That gives you more clamping diameter and more clutch options. I have an 1800 flywheel, plate and pressure plate spare but they belong to someone else. I'll ask if I can pass it on.
the pressure plates are usually okin terms of clamp pressure.
maybe just put in a 6 paddle or 4 paddle center if you want a "hd" clutch on a budget.Get you r flywheel shaved while your at it.
I got my 1800 HD clutch from Don at autoways for about $300 at the time.
cool cool, you guys both make valid points, ill make a phonecall or 2 tomorrow to see what i can find, right now im doing the engine pull, so far so good, back online tomorrow
thanks heaps for the advice
Psycho_Dad
Psycho_Dad
Re: NA6C Clutch
I manage the Autostop shop in Henderson, Auckland. If you still need a clutch i can price a new standard one for you if you like? let me know if you need
regards
Peter
regards
Peter
so i replace the engine, car idles perfect, but has no omph, like the timings real retarded, but its at 12-14 degrees, im getting over 40psi fuel pressure, and as far as i can tell im getting spark
my 4th sparkplug is a lil dirty, but if i run the engine on 3 cyl by unplugging a spark plug lead, it doesnt matter what one i unplug the engine sounds the same while revving... dying
i did have a blocked fuel filter, but thats fixed now
ideas
suggestions?
possibly a dead injector?
PSycho_Dad
ideas
suggestions?
PSycho_Dad
