VEight 400HP WideBody MX-5
Here my forst try to see if I can post with links now...
My little baby while the wide body is in construction...
http://www.bfamus.tv/watch.php?mdid=391 ... ght+week+4
Antony
Miata VEight
Miata VEight
It's working !!!
So now that the forum is working I will have the chance to share with you my little crazy project... Here where I am now. Finition is comming good too after only 4 weeks of labour...
Some also like pictures, here are some interesting pictures for you;
This one is showing this Camaro SS hood scoop. I've had one in 1997 and this is the who gave me this love of V8 unique sound and torque;
In this image we can see the aggresive look of the whole new design;
We can see here the finition made behind the rear wheels, if you look carefully, you will notice how the tires are streched-in because of the 12 inches mag wheels, still 275/35/18 on !!!
And finally a more overview image of the car;
I have some more images posted here:
http://www.bfamus.tv/watch.php?mdid=391 ... +semaine+4
Now, we still have to finish the rear carbon deflector, the front grill (still not fixed for the look, looking at the 612 Ferrari style), the sides to cover the mufflers, finition on the wheels (they were not new) and a whole lot of finition before the molds !!!
Comming soon...
Comming soon...
Antony
Miata VEight
Miata VEight
nice
what flavour v8 is going in there?
Re: VEight 400HP WideBody MX-5
I believe the LS6 Corvette engine. Lets hope it isn't the 454 big block variety as it will be waayyy to heavy. Probably the 350 more likely.
LS6 Gotcha
Yea,
I bought a LS6 with 6 speed man trany comming out of a 2005 CTS-V. Think it' gonna rock well
Antony
Miata VEight
Miata VEight
Hi All,
If you wanted a high horsepower engine but not the weight ( and bulk ) had you thought about the 454sbc crate engine with claimed 600hp at 6,400 rpm and 584 lb-ft at 4,500 ? Also wasnt the LS6 a 454bbc ?
Cheers Folks
John
Cheers Folks
John
Now...I could be wrong but I believe the LS6 was a big block from the 70's. The later versions LS6 is the small block which is the same engine in some of the Corvettes and the Holden Commodore (5.7).
Wide Body MX-5 - Week 5
Hi again....
Here we are at week 5, preparing finition touch before moulding and then TOTAL DESTRUCTION of this package (This will be the most crazy video of all
And for those who are following this Wide Body miata project, here is the latest video filmed yesterday in Drummondville, Qc: http://www.bfamus.tv/watch.php?mdid=413 ... ght+week+5
And now in pictures:
For those of you who understand french, I'm askin some questions in the video... If you want to get back to me with your ideas, it would be great !
SOME MORE PICTURES HERE : http://www.bfamus.tv/watch.php?mdid=413 ... ght+Week+5
Thanks again following my project of a lifetime ! To be continued in about 10 days !roject of a lifetime ! To be continued in about 10 days !
Antony
Miata VEight
Miata VEight
Hi Guys, Not trying to be a no it all but over here I havent heard of an LS6 in any Commodores and nor has the local Holden Dealer ( they seem to believe that there was only the LS1 and LS2 but I know that there was an LS6 but was only a BBC...If anyone can find any different information can you please send it to me so I can be corrected cheers) Also 400hp sounds respectable ( I have read somewhere that the corvette puts out like 400kw and we get the detuned version...unfortunatly )
John
NA 400sbc, Turbo 350, 7.5"Mustang Diff
John
From Wikipedia
LS6
GM LS6 engine in a Chevrolet Corvette Z06LS6 can also refer to a 454 CID Chevrolet Big-Block engine of the 1970s
The LS6 is a higher-output version of GM's LS1 engine and retains the same capacity. The initial 2001 LS6 produced 385 hp (287 kW) and 385 ft·lbf (522 N·m), but the engine was modified for 2002 through 2004 to produce 405 hp (302 kW) and 400 ft·lbf (542 N·m) of torque. The LS6 was originally only used in the high-performance C5 Corvette Z06 model, with the Cadillac CTS V-Series getting the 400 hp engine later. The V-Series used the LS6 for two years before being replaced by the LS2 in 2006. For 2006, the Z06 replaced the LS6 with the new 7.0L LS7.
The LS6 shares its basic block architecture with the GM LS1 engine, but other changes were made to the design such as windows cast into the block between cylinders, improved main web strength and bay to bay breathing, an intake manifold and MAF-sensor with higher flow, a camshaft with higher lift and more duration, a higher compression ratio and a revised oiling system better suited to high lateral acceleration. [1]
The casting number, located on the top rear edge of the block, is 12561168.
Applications:
2001-2004 Chevrolet Corvette C5 Z06
2004-2005 Cadillac CTS V-Series
Mine was issue from a 2005 CTS-V Cadillac...
The wikipedia link here: http://en.wikipedia.org/wiki/GM_LS_engine
Applications:
Antony
Miata VEight
Miata VEight
Hello again All,
I apologise to all and I appreciate the information given to me by Antony ( Bfamus ) and look forward to watching his progress with his project as I build mine at the same time. Have you thought about what diff you will be installing Antony ?
John
John
Differential
Hi John,
Please don't worry with this, we are here to share and discuss and I could have been wrong
For the diff, It's actually a stock Ford 8,8 out of a V8 97 Thunderbird. Honnestly, I don't even know if it's LSD
... the gear, if I read the web would be 3,08 (very low). I'll start with this and I will see.
My plan would be to change the actual ration to 3,73 LSD...
$$$$ again
$$$$ again
Antony
Miata VEight
Miata VEight
Hi Antony,
That really is strange how they do their engine codes...Too hard to keep up with them
Have you spoken to a guy named Martin at Monster Miata in San Marcos, California? I got my diff etc off him ( just to make it easier for me
) He uses the 7.5 diff cos on the stock Miata ( not the wide body like yours
) the half shafts touch the shock towers. I would think that the 3.08 should be fine ( 60MPH should be at like 2000RPM ) but then it all depends on what you are wanting to do with it. I went with 3.27 so should be ok for street, strip and circuit but im building it to drive when I feel like it
With a ratio 3.73 I would be thinking that you are building it for strip ??
All the best
John
All the best
John
John
John
Dont't know yet
Honnestly, there are so many modification made that i don't know how it's gonna feel. The wheels are so big, this will also make a huge difference... I will try it like that and see ! Will let you know for sure
For Monster Miata, never talk to him... not yet though...
New video comming soon...
Antony
Miata VEight
Miata VEight
Monster Miata Week 6
Here is my most recent home made video http://www.bfamus.tv/watch.php?mdid=443 ... +V8+week+6
Finally, we just finished the front bumper, the two holes will serve one for foglights and the inside one for brake breathing with a functionnal conduct.
Here, the front bumper:
Here a tails light picture:
Side covers, covering exhaust like I explained earlier (not finished yet):
And finaly, here the preview after 6 weeks of hard labors;
Antony
Miata VEight
Miata VEight
Antony
Miata VEight
Miata VEight
Here's how we do it !
So by the time Jimmy's working on producing the parts (it's a little longer because he had a car accident... :bang: but he's not too bad !) we just started working on the mechanical aspect.
Ryan (my mechanic) had the time to put the engine in it's hole 2 times in the first 3 hours the car was in it's garage! He rocks !!! I haven't made any pictures yet but I promess I do some next time. Here my first video of the Miata Monster LS6 !
http://www.bfamus.tv/watch.php?mdid=740 ... a+LS6+swap
Antony
Miata VEight
Miata VEight
TALKINN ABOUT SERIOUS MOTIVATION...
Watch out those amazing video and feel the lightpowered V8 Miata against those muscle giants cars as they just loose it !!! Ha Ha !!!
Against a Mustang Cobra 2003
http://www.bfamus.tv/watch.php?mdid=743 ... g+Cobra+03
Against a Nissan 300ZX TT
http://www.bfamus.tv/watch.php?mdid=743 ... +in+tunnel
Against a Trans-Am with 410 whp !!!
http://www.bfamus.tv/watch.php?mdid=743 ... p+Trans+Am
And finally an inside cam to feel the V8 inside the cockpit!
Just MENTAL !
http://www.bfamus.tv/watch.php?mdid=743 ... a+on+track
I could not resist to share those videos with you as it's helping wait for my toy to be ready !!! Wish it can help you wait to sumer too...
Just MENTAL !
Antony
Miata VEight
Miata VEight
Hi All,
Those just show you what they can do . Just some videos that I thought that you might also like.
Lexus Tiwn Turbo V8 Miata.
www.youtube.com/watch?v=gncfIvMRdSs
Have you heard of this company? Hp seems abit low for a Blown V8
http://www.fastlane.com.au/Custom_Shed/AEC_Bullet.htm
John
John
Nobody has friends over 200mph
Seen it before
Yeaaa thanks !
I've seen it before, should have shown you
Amazing hein ???
Amazing hein ???
Antony
Miata VEight
Miata VEight
This is at Ruapuna in Christchurch. Last time I was there there was a guy with a white MX5 running a 13B Turbo motor. That seemed pretty quick too.1Hotmx5 wrote: Lexus Tiwn Turbo V8 Miata.
Hi,
Yeah I thought that this was a NZ car but wasnt too sure as when I saw ( a few years back ) it didnt have the turbos so was unsure. I would like to put turbos on mine but I dont think that I have the room...will take another look when Ive finished it.
John
To: horsepower@mx5forum.co.nz
Sent: Tuesday, 10 March, 2009 12:47:15 PM
Subject: [MX5Power] Re: VEight 400HP WideBody MX-5
John
1Hotmx5 wrote:
This is at Ruapuna in Christchurch. Last time I was there there was a guy with a white MX5 running a 13B Turbo motor. That seemed pretty quick too.Lexus Tiwn Turbo V8 Miata.
www.youtube.com/watch?v=gncfIvMRdSs (http://www.youtube.com/watch?v=gncfIvMRdSs)
