HA-HA Cambelts broken
PLSEME
Post by PLSEME » Thu Oct 02, 2008 8:34 pm
:lol:
Yea so im driving home after work & suddenly the motor cuts out ,
Lucky i was just round the corner from home so i called up a mate round the corner to help me get the mighty MX home.
after checking one or two things i took a look in the top of the engine while we turned it over (hey check that out the cams arnt moving)
:( So Cambelt is deffinatly gone as iv just stripped it all apart .
so tomorrow im off on the mission for the parts so i can start putting her back togeather on Saturday :cry:
Cambelt
Tentioner pully
Idler Pully
Water pump
Is there anything else people can suggest i should do while im in there :?: ,I am of the understanding these are a non interferance engine :?: & is setting the timing the same as in the 1.6 :?:
Oh yea should mention its a 93 Import 1.8 NA8C,
Thanx for your feed back :D
Post by Growler » Thu Oct 02, 2008 10:39 pm
I have never replaced a cambelt on a 1.8 so can only assume they are the same or similar.
I would recommend getting a new crank nose bolt that bolts the bottom cam belt pulley on.
As you have to torque them up quite high the bolt can "stretch" over time.
tle_nz
Post by tle_nz » Fri Oct 03, 2008 10:35 am
While you've got the engine apart anyway, I recommend putting in some forged piston heads, re-boring the engine to 2l, get some new racing cam shafts, chuck a massive turbo in there. Y'know, just some minor things :D
madandy
Post by madandy » Sat Oct 04, 2008 10:19 am
A good coolant flush & maybe new hoses.check & re-gap plugs as required...just a good service opp.
You could get real flash & remove the HLA's to inspect & bleed them.
Post by Euen » Sat Oct 04, 2008 8:32 pm
I would recommend doing the water pump and thermostat while you have it all apart.
If you haven't already got all the bits, BNT do a kit that includes the belt, tensioner bearings, tensioner spring and new cam bearings. All you need in one box.
