Which Spark Plugs for a 1992 NA
Sugoi
Post by Sugoi » Fri May 30, 2008 11:03 am
Hi There,
I figure that it is about time to replace the spark plugs, but do not know which brand or model to use. I do not even know what the stock ones are for it, and figure that someone might be able to tell me what these are, or if there is a better after market / upgrade option.
I was also wondering if I need to replace the spark plug leads or not? I have 170,000 km on the MX-5 and it is a 1.6 litre model, if that makes any difference.
Bye for now :D
Badcat
talk to ross - www.mx5mart.co.nz
Post by Badcat » Fri May 30, 2008 11:29 am
hey.
my suggestion is to use ross at mx5mart - excellent parts an d service at great prices.
spark plug leads - NGK are the best:
http://www.mx5mart.co.nz/db.cgi?db=mart ... records2=1
spark plugs - NGK BKR6:
kind regards
ken
Post by Ian » Fri May 30, 2008 2:21 pm
The factoy recommended NGK plugs work just fine.
If you are using factory or budget aftermarket plug leads, prepare yourself for a case of chronic misfire...I was warned about this when I first got my car, but it was still a shock when it occured. A set of Repco Champion leads fixed the problem, but have since upgraded to some high performance Racing Beat leads which 'should' last longer.
NGK plug leads would seem to be a cost effective way to go....as advised - Ross at MX5 Mart can do plugs and leads...
Post by brownie » Fri May 30, 2008 8:57 pm
NGK, BKR6E-11 or Platinum type BKR6EVX-11 i think,Can't go wrong with these ,Platinum are long life and the best to use.
No worries,
If you get stuck contact me at work,Mazline Partsworld,0800 323 626 and i can sort a sharp price for you,
Mark
