Pop-up light intermittent actuation fault
The pop-up headlights on my 1992 Japanese import MX5 (Eunos) 1.6, sometimes take a while to come up and sometimes stay up for quite a while after the lights are turned off. Both lights move together, but some time ago the RH headlight kept popping up and down on its own. This has since stopped. I have silicone sprayed the light switch stalk and the actuators by the headlamp units. Where else can I look for the solution to this problem?[[/list]
Slydit posted a solution to this in the old forum.... I'll see if I can find it.... and after far too many search results here it is...
http://www.mx5forum.co.nz/viewtopic.php ... +behaviour
Good luck....
Good luck....
i dont have that problem since i dont have the barn door lights anymore i have now uesd the light button as the last part of my kill switch / immobiliser system
i do have the problem that sometimes when i turn on the indicators i flash the high beams i think i need to wip the swich out and give it abit of a refurbish
