THE PROJECT UPDATE THREAD FOR MARCH
Post by SLYDIT » Sat Mar 15, 2008 2:10 pm
ALRIGHT...WHATS EVEYONE UP TO THIS MONTH???
WHAT PROJECTS YOU GOT ON THE GO???
(Its ok Poison, you can watch this thread, dont feel bad about not having anything to add this month :lol: )
Additional spice!
Post by Habanero666 » Sun Mar 16, 2008 11:12 am
Hey there, the Habanero is calling again!
*This month will see a completly revised intake system,
(Removal of MAF sensor)
also some measures taken to duct cold air onto the new air filter set up.
*Intercooler water sprayer using the original screen wash reservoir and some number 8 wire.
*Revised air bypass valve and vacuum routing.
*Installation of new dual exit turbo dump pipe.
*Tune the Fm Link.
....Should keep me busy untill the end of this month anyway :D
Post by jif » Sun Mar 16, 2008 9:58 pm
and for something completely different - I'm unpimping my ride ...
- swap bucket seats for std leather ones (done)
- make the pwr steering "stock" again (half done!)
- put stock wheels back on (need to buy a pr of tyres first)
- find and reinstall stock ECU (and injectors)
- put on the "go-slow" mods ...
...etc
Post by poison » Mon Mar 17, 2008 9:52 am
What????? Why????? Oh No, Don’t telling me you’re leaving the world of MX5’s, just upgrading to an NB/NC I hope!
What are the bucket seats out of? I tried a few after market seats but always ended up sitting too high.
Post by Euen » Mon Mar 17, 2008 2:37 pm
Jif, I wish I'd known you were repowering your rack, I could have saved you the job as I am looking to depower mine.
Other activities, had to replace the gearbox as the synchros on reverse were worn so that I could not engage 5th. Replacement box is in, now just tightening everything back up before the Pukekohe sprint on Sunday.
Post by Ian » Mon Mar 17, 2008 5:39 pm
Ummm.... Scruffy white hardtop now repainted classic red and has a 3mm tinted lexan rear screen screwed in place. Entire softtop in the garage as a weight saving measure.
Momo gear shift knob for added 'bling'.....to compliment Momo Commando s/wheel.
An imminent move south to Q'town mean a reaquaintance with Teretonga and the proposed new Cromwell circuit is on the cards. 8)
MN
Post by MN » Mon Mar 17, 2008 6:25 pm
General maintenance - bearing on the gearbox input shaft is noisy (so I'm told), replace the clutch (as it slips on the odd occassion) and if things have to come out then why not look at replacing with an 1800?
cheers,
Mark
2low2c
Post by 2low2c » Mon Mar 17, 2008 8:56 pm
jif if you want to change your ecu
you will need to rewire it before you plug it in (as I rewired it for the link)
or you will need to get a93-95 1.8 ecu .
