NB Turbo - What's the best timing?
Post by poison » Sat Mar 08, 2008 7:01 pm
Today I re-plumbed the blow off hose to "T" off a different vac hose. Wow what a difference it releases on every gear change, before I could hear the waste gate chuffing at lower boost gear changes and had spent too much time and money trying different BOV's thinking that was the problem.
Anyway under boost it runs way too rich so rich it drops off the bottom of the O2 wide band range (11.1 afm) so I have some room for more boost. So I adjusted to length of the waste gate actuator rod, and air/fuel up to about 12.4 under boost at about 4500rpm. And holy crap it went like a rocket, but started to knock :( so I had to back off the boost again - I have no idea what it’s boosting as I did not have the gauge fitted - it was just bordeom fiddling.
What timing should I have at idle? And are there any hoses I need to disconnect or anything to do before setting the timing?
Post by jif » Sat Mar 08, 2008 8:05 pm
Hi Gaz
suggest you aim for an AFR of something lower if that's the case... 11.x : 1 or so
I didn't think the NB timing was adjustable, but the FM maps are something like ~15* timing (absolute) at 12psi at 4500rpm. 20* seems about the ragged edge with good octane at lower altitudes. Not sure how that works with the e-manage tho! You need to enter the timing difference between that and the stock value, or something?
Post by SLYDIT » Sat Mar 08, 2008 8:23 pm
are you running my default timing map i loaded in to the emanage when i set it up for you????
try an retune your afr's to about 11.5-12:1
12.5:1 is too lean on an NB at anything over 6 psi...Richen it up a bit then re do your timing.
You can data log your boost if youve hooked in the boost sensor into the emanage.(in fact the timing map wont work if you dont have the map sensor hooked up and set up for my map) what map sensor did you get in the end??
with the emanage DATA LOG IS YOUR FRIEND! USE IT AND LEARN TO LOVE IT :D
Post by poison » Sat Mar 08, 2008 11:23 pm
Thanks, but no I haven't done the eManage yet :( I was just screwing around today and decided to play with the boost. I assumed it should be 5 deg less than a standard timing. I haven't checked to see yet. Of course the best thing would be just to put in the eManage :)
Returned Mail: Re: Re: NB Turbo - What's the best timing?
Post by poison » Sat Mar 08, 2008 11:32 pm
Ok ignore all that, Jif is on the ball as usual. Seems the NB does not has
an adjustable CAS (Cam Angle Sensor). Well at least I know where I should
end up once I get the EManage in... need a Round ToIT.
Returned Mail: Re: NB Turbo - What's the best timing?
Post by jif » Sun Mar 09, 2008 9:12 am
just remembered... some NB folks have made it adjustable by slotting the CAS mounts/brackets :]
Post by SLYDIT » Mon Mar 10, 2008 9:13 pm
AND THE AWARD FOR THIS YEARS BIGGEST PROCRASTINATOR GOES TO...........
POISON!!!
TAKE A BOW!!! :D :D
OR MAYBE TAKE ONE LATER! :wink:
Post by poison » Mon Mar 10, 2008 11:09 pm
SLYDIT wrote:AND THE AWARD FOR THIS YEARS BIGGEST PROCRASTINATOR GOES TO...........
POISON!!!
TAKE A BOW!!! :D :D
Oh God yes, and I never got around to writing my speech either :lol:
