Can anyone please tell me - is it the same key for all locks in my MX5 1989 model. ie. door, ignition, glove box and central storage console. My ignition key doesn't seem to work on the storage compartments.
keys
keys
Yes it is, so I’d guess some of your locks got replaced at some stage. The console and glove box one’s are simple so I imagine it would not be expensive to have them re-keyed. Also if your console will not lock, it would be a good idea to disconnect your boot release so anything in there is secure.
keys
If yours is an early car then it was supplied from the factory with one key that worked everything and one key that just worked the doors, boot and ignition. The theory behind this was that if you went to a hotel where they park the car for you, you handed over the key that didn’t open the storage compartment and your belongings would be safe.
Ryan Orr
I'm not sure about Fingaz' 2 key comments for earlier cars (I've never heard if it), but I can tell you should have a key that will work everything. If Fingaz is correct - you obviously have the non-console key, but you might be able to get another key made to fit everything by a good locksmith.
Does your ignition key open the boot & door locks?
It is possible that just your ignition barrel has been replaced at some stage, as I know mine has. I've seen a couple of MX5s with broken keys in the ignition barrel, and some that have been screwdriver forced, so they replace the whole barrel. I don't know what happened to mine - I have always had 2 keys.
Therefore, I have 2 keys, one for ignition, and one for boot/console/glovebox/doors. It doesn't worry me, and is actually quite good if I need to give the key to someone to drive it (it has remote unlock/lock).
FWIW, you can get a competent locksmith to set up your ignition barrel to match another key (one that will work on your console etc). It is easiest if you take the key and the whole barrel (you can unbolt/unplug it from the steering column) to the locksmith.
Also, as poison said the console/glovebox aren't as sophisticated as the ignition lock as I know a few keys from various cars can be swapped amongst consoles. You have to wiggle them around a bit but the hit rate was higher than I thought it would be.
I've also taken a similar barrel on an MX6 apart to remove a broken key... I won't be doing that again in a hurry! I spent a very long time getting the springs/tumblers etc back in the right place...!
key cut
Hi there, I fixed my problem by getting a new key cut!
When the profile of the key wears out, it doesnt work in the least used locks. my old key doesnt lock unlock the glovey or centre console...new one does. Hope this helps.
Hab
Hab
