Wanted: Engine and gearbox
I'm wanting to re-engine my lotus 7 and seeing as the MX5 has perhaps the best gearbox in the world and the engines are small and light it seems a perfect choice.
Either 1.6 or 1.8, I'm not fussy.
021 022 96120 or (03) 365 7753
Mat...
Keith Tanner has written a book on building a Lotus 7 type car using an MX5 as a basis. Not sure if that would be of any help to you? (you can access some of the detail via the Flin Miata website)
MX5 Mart in Hamilton currently has a low mileage NZ new NB 1.8 engine and box in a car (can be heard running) This would make an ideal unit (with its ecu)
Cheers, Ian
Cheers, Ian
Now thats good timing. Sold my recently purchased mx5 to buy my wife an
automatic car and already feeling a bit lost. Have got a set of plans for a
McSorley chassis (a set of plans based on the Champion chassis) and have been
tossing up how I can put them to use.
I also have a $70 book voucher burning a hole in my wallet
Watch this space....maybe a chance for a section of the forum devoted to MX5
derivatives if "he who must be obeyed" feels so inclined.
Maybe I'll hang around here even tho the MX5 has gone.
GerryAttrick
Thanks Ian,
My lotus is already built but that book might be helpful.
I'll contact ross and see what he wants for his setup, I'm also thinking of despensing of injection and fitting the two 40mm twin sidedrafts I have on the current crossflow to the mazda engine.
Mat
As you would have to build a new manifold for the side drafts anyway, why not look at independent throttle bodies instead. I guess there is the downside that the standard computer doesn't like them, but then, how does it react to carbs.
The reason for me wanting to go down the carb route is simplicity, but I'd still need to find a way of running the ignition so in fact it might just be easier to leave the mazda engine as stock, run the stock ECU and sell my X-flow running gear complete with carbs.
Oh so many choices!
Oh so many choices!
Mat..
Yes, I appreciated that the car was already built, but imagined there might still be enough useful info to be worth checking it out if using an MX5 engine/box. Grassroots motorsport are currently doing a build on an MGB using a 1.8 miata engine and box. They will eventually supercharge it, but intend to do the install with injecton and n/a at this time.
Ross is asking $900 + gst for the engine complete!!!! Its a steal (in my book)
Yeah the book book would be really helpfull,Ian wrote:Mat..
Ross qouted me $1500+gst for the 1.8
