Different Speedos
Different Speedos
I discovered yesterday that when I reached 180 on the speedo the engine started to cut out , just like it does with the rev limiter but in this case there were still 500 or more revs to the start of the red line. This happend a couple of times. And before anyone starts getting concerned this was on a closed road with full safety gear and perfectly legal.
I doubt I'll get that fast very often (first time in 3 years of motorsport with this "5") but is there a way to change that top speed cut out? I understand that some models have guages that read to 200 (or 220?) if so which and what is the conversion process to a 1990 NA?
cheers,
Mark
Mark
i Have heard that the speedos hava a simple pin in the speedo gauge mech behind the gauge face that activates the cutout at 180...removing the speed limit is a simple procedure of removing the wire to the pin on the gauge cluster...
Never tried it......... cant prove that this is the case either....worth a look.
Different Speedos
the local models go up to 220km/h on the speedo
not that you'd ever hit that in stock-ish form!
I know this is the case with alot of rotary model mazda's so it would be worth a look.SLYDIT wrote:i Have heard that the speedos hava a simple pin in the speedo gauge mech behind the gauge face that activates the cutout at 180...removing the speed limit is a simple procedure of removing the wire to the pin on the gauge cluster...
i belive it is a screw of sorts
Have personally removed the 180km limiter screw (clearly marked as such) on the rear of a 1986 RX7 turbo which enabled me to do 225kph.
Suggest you look at the rear of an MX5 speedo assembly at a wreckers as a first step...
Mine only does 175kph on the straight (thus far), but is NZ new, so don't anticipate any problems at 180 plus.....(apart from heart palpatations!)
Different Speedos
Hi Mark, Just Google Mazda MX5 speed limiter removal & it will take you to the clara.net site. This has other MX5 stuff somthing like the garage section of Miata.net
Hope this helps.
Brent Weaver
Hope this helps.
Brent Weaver
Different Speedos
I have just had a look at a spare instrument cluster I have in the garage that came out of an 1800 series I. There is a screw that that has 180km/h SW printed beside it. When the screw is removed, the contact is cut between the printed circuit and the speedo sensor. Had trouble running fast enough holding the instrument cluster to see if it works!!!!!
Different Speedos
on 9/07/2007 8:55 p.m. MX5PWR wrote:
(Still on Christmas Island... and it is now raining - in the dry season)
Do you have your camera handy? A pic would be useful...I have just had a look at a spare instrument cluster I have in the
