MX5 seat height adjustment
JOHNBOY
Post by JOHNBOY » Tue Jun 05, 2007 6:26 pm
Just purchased a yr 2000 MX Roadster I am a six foot boy!!!
Has anyone any experience with lowering the seat rails??? even one inch would help...drivers side only .. :lol: Johnboy
Post by zorruno » Tue Jun 05, 2007 7:13 pm
I don't really think you'd be able to lower the seat at all. You can remove some padding from the seat base though, and I know others have done it.
Someone else may be able to give some pointers on doing this.
Post by zorruno » Tue Jun 05, 2007 7:24 pm
actually, I had a look around and found some discussion.
I made a howto (link to miata.net) here:
http://www.mx5forum.co.nz/viewtopic.php?t=8445
This was for a 94(NA), but I assume you can do a similar thing on an NB.
If you attempt this, please take some pictures for our howto.
Miatamad
Post by Miatamad » Tue Jun 05, 2007 10:17 pm
I did this on my 89 - not so much for height (im short :cry: ), but because it made the seat more 'huggy' for spirited driving. Unfortunatley this was a while back and I didnt take any pics.
I can tell you that it does make a difference, and feels better IMHO.
Take heed of the warning in the miata.net instructions - it really is sharp under there. Bloody can be removed fromthe seats with fabric cleaner.
C
Like my post? Give me Karma!
Boosted. Scary fast.
JOHNBOY
Thanks to all you enthusiastic MX5 drivers...
Post by JOHNBOY » Tue Jun 05, 2007 10:45 pm
Have noted that the latest model 2007 has raised seat rails..allowing some modification ..
I will investigate the possibility of chopping the seat tubes if there are any .. Johnboy
Gordon Tucker
mx5 seat height adjustment
Post by Gordon Tucker » Wed Jun 06, 2007 1:15 pm
I'm also tall with long legs. In the NA's and NB's that I have owned, I remove the drivers seat and unclip the seat bottom cover at the front. i take some foam out of the seat base, but I also insert more foam on top of the front bolster to give me more support under my thigh. I also carry extra thigh support (foam pad) for extended trips. The best cure that I have found though, is to get a NC -more cockpit space and legroom :lol:
JOHNBOY
MX5 SEAT LOWERING
Post by JOHNBOY » Wed Jun 06, 2007 4:14 pm
Thanks for that ..i will investigate the removal of seat foam ..
Regards Johnboy
JOHNBOY
MX5 seat lowering
Post by JOHNBOY » Wed Jun 06, 2007 4:18 pm
Thanks for that i will try removing some foam ..
Regards JOHNBOY :wink:
Users browsing this forum: Bing [Bot] and 10 guests
