Just wondering if anyone else is having or has had this problem. The plastic
window on my soft top is starting to get some sort of grainy white build up on
it at the bottom. I have tried to clean it off using just water, then soapy
water, but it won't shift. If I scratch at it I can kind of get it off but
it's hard going & probably is not good for the window itself. Can anyone
suggest the best thing I should do? From what I have been told the roof
itself/window is a replacement and relatively new and I'm not quite sure why
this is starting to happen (I've had it over a year now). Anyone's help would
be gratefully appreciated.
Tj
Build Up On Window
Build Up On Window
I think it is caused by the roof sweating a little, when it is down.
I have had good success with Mothers Plastic polish.
Massaged in and then buffed off.
Its one of those things that gets better results every time you use it.
Colin
Colin
