My soft top is getting to the stage of needing replacing. I have heard that there
is a supplier in the Wellington area who can supply the Robbins brand.
Does anyone know of the supplier or any other avenues at reasonable cost.
__________________________________________________
Join ZFREE and enjoy free web-based email accessible from
Internet enabled PCs around the world.
Register now at: https://e-care.zfree.co.nz
Soft top
Soft top
Rotary Power supplied my Robbins tan top they are agents for Moss Motors and give
club members a discount, or you can deal directly with Moss, you will find Moss Motors
most helpful. It will still be cheaper than one from Mazda even though our exchange
rate is awful.
In answer for you Ross
i fitted my top myself, if you can change your oil you can change your hood, consider
getting the glass window version, a tip, remove the seats makes installation easier,
the hood can be changed on the car, if you are in Auckland i can supervise if you
like, i'm good at that, have supervised 3 so far.
Ray
Internet enabled PCs around the world!
rate is awful.
Ray
__________________________________________________is a supplier in the Wellington area who can supply the Robbins brand.
Soft top
Als Upholstery North Shore have Robbins Tops in stock $1095.00 plus GST
fitted.
or $1165 plus GST with modification clips to stop wear in folds.Tel 4431581
At 20:33 07-12-00 +1200, you wrote:
fitted.
and giveRotary Power supplied my Robbins tan top they are agents for Moss Motors
Moss Motorsclub members a discount, or you can deal directly with Moss, you will find
exchangemost helpful. It will still be cheaper than one from Mazda even though our
hood, considerrate is awful.
installation easier,getting the glass window version, a tip, remove the seats makes
if youthe hood can be changed on the car, if you are in Auckland i can supervise
that therelike, i'm good at that, have supervised 3 so far.
Ray
Soft top
I take it the window does not unzip, and does it come with the rain rail? most
are not worth swapping as they become brittle or are already split, thats if
your hood has one of course, mine didn't, hence the water in the boot, you
learn more about these cars the more you check around them, and also this forum
of course,
keep up the good work.
Ron
of course,
Ron
