Does anybody know how to get the vent rings off the air vent? I can pull it out of the dash but not sure on how to remove the ring from the rest of it. It has heaps of clips but hard to get it off and I don't want to crack it.
Any tips?
Debra
chickclick.com
http://www.chickclick.com
girl sites that don't fake it.
http://www.chickmail.com
sign up for your free email.
http://www.chickshops.com
boutique shopping from chickclick.com
vent rings
vent rings
Just yanking them out worked for me, but mind you don't scratch anything.
There is an excellent writeup showing a couple of methods with pics to be
found here
http://www.miata.net/garage/eyevent.html
Good luck
H
found here
Good luck
H
vent rings
you can use a piece of wire with a hook on it it is only the spring
clips holding them
if you plan on removing the panel the two centre vents sit in there are
two screws hidden inside at the top
Ray
clips holding them
Ray
vent rings
Debra,
I removes mine some time ago, as I was experimenting (unsuccesfully) with
painting them.
They just unclip, as you suspect. I used several small flat-blade
screwdrivers to hold some clips open while I unclipped the rest.
I didnt have any trouble with cracking/breaking the rings, but experience
with other parts of the dash show that the plastic does become brittle after
years of exposure to the sun, so this is a valid concern.
Good Luck,
painting them.
Good Luck,
vent rings
the vent rings have four tiny plastic clips that hold it in place they
are very difficult to remove without damaging the rings as they will not
give when pushed in, you could try warming them in water then trying to
prise them off at each clip with a screwdriver inserted between the ring
and vent, why do you need to remove them? are you replacing them with
another type?
Ray
another type?
Ray
