Hi all
Just put a new Panasonic battery in my 90 NA yesterday to replace the
non-standard non-vented type. However, the vent hoses are missing.
Anyone got any advice on where to get some? The plastic fitting that
goes through the boot floor is still there, I just need the hose(s). I
presume there are 2 hoses that join in a T or Y adaptor before
connecting to the plastic outlet?
Dave
battery vent hoses wanted
There should be a plastic battery tray. The rubber hoses do go to a T
and then a single hose down to the boot floor. That's how it is on my
'90 NZ car.
Jon Addison
'90 NZ car.
Jon Addison
I'm now curious to see just what the standard set-up of hoses and tray
looks like. Is there anyone on the list in ChCh whose car I could take
a look at, or could anyone send me a pic? I realise I can make up the
hose and do without the tray, but in one way I'd like to keep the car
original.
Dave
original.
Dave
Hi, Dave
For what it's worth I suggest that you do get a tray for your battery. It
has two large dimples in the bottom that locate into the metalwork & the
whole thing helps hold the battery securely in position. Ross Campbell of
MX5Mart or your local Mazda wrecker should be able to help out.
I did fabricate my own version of a tray while I had a non-standard battery
in the car - a plastic tray from Payless Plastics & a heat gun worked
wonders. Not as good as the original though.
Regards,
Greg
Regards,
Greg
Greg
1990 V Special
1990 V Special
Dave...
In Ch Ch...you can look at mine.
Txt me at 027 220 3525 to set up a time and place. Will be passing your
place of work tomorrow.
