Brake changes info
Brake changes info
Post by Ian » Sun Feb 12, 2006 10:19 am
Chris...
I have an 1800 NA , and am looking to give it brake 'freshen' without going
larger (1800 NA brakes bigger than 1600 NA, as you are probably aware)
Can you advise the model/type of Brembo disc you used and source/cost?
Also details of the pads, please.
From memory, you mentioned braided lines, recently..I could be a starter as
long as there are no WOF issues, which I suspect means the lines would come
with a certification or similar attached to them?
Thanks, Ian
Return to “2006”
