I rang the Loctite guy today regarding which Loctite product
to use on the front crank pulley shaft, he asked if it was a
clearance fit (pulley can be removed by hand) or a press fit
(needs force/tools to remove or put back on). They each use
a different Loctite product. So can you guys tell me if the
pulley was a loose or tight fit please.
Fletch or Karl (or anyone else who might know…) Is the front
Assuming clean surfaces etc, the pulley just slides on, so by yourI rang the Loctite guy today regarding which Loctite product
definition I'm going to call it a clearance fit. Certainly no press
required.
This article http://www.miata.net/garage/hsue/LoctiteCrank1.html
details the recommended loctite products. I rambled about the topic
in various emails here between about 14-19 August 2004.
Karl.
