Hey David
they seem to use that white grease in many electrical appliances, even in
VCR's and DVD's on the gears and runners. Didn't know it was lithium, where
did you find it? I've only found red and blue lithium so far. Also I wonder if
the stuff is toxic, as far as I was aware lithium was pretty bad for you. You
should be able to answer this one.
"PO1SON"
Window: What goes up does not come down
I bought an aerosol can of the stuf from Repco in Onehunga. It is toxic and
affects the nervous system and kidneys I think - very messy either way.
David
