lumbar - any success?
Post by poison » Sun Oct 17, 2004 11:05 pm
Hi zorruno (or anyone else)
Every time I drive the MX for more than an hour I get a pretty sore lower back
too, usually when I stand up and try and walk somewhere. So I was wondering if
you had any success, and if so have you any tips that may be of use before I
embark on some experimentation.
"PO1SON"
EricW
Post by EricW » Mon Oct 18, 2004 7:26 am
You used to be able to get what was called a "Lumbar Roll" from the Chemists,
I had a couple of them. They are like a 75-100 mm diameter roll of medium-soft
foam in a cloth outer and worked a treat.
From memory they were about 250 long, so if you can't buy one you could
probably make one up. I think the trick in making one is that it needs to be
cylindrical over it's length, not squeezed together at the ends like a
sausage, if you get my meaning. That way it locates itself across your back,
rather than trying to slip out the side.
Hope that helps
Thomas Beagle
Post by Thomas Beagle » Mon Oct 18, 2004 7:33 am
I used to have that problem.
The solution I found was to slide the seat forward and then lean it back
a little bit more.
Thomas
Gazza wrote:
redwon
Post by redwon » Mon Oct 18, 2004 9:05 am
I have something similar. It's a "D " shaped piece of foam rubber, cloth
covered. A friend who worked in a hospital "borrowed" it for me. The flat
side
of the "D'" goes against the seat and the round side against your lower
back. After a few kilometres you can' even feel its there but at the end
of a long drive you don't get out of the car looking like a cripple.
Steve
_____
Eric & Ann West
Sent: Monday, 18 October 2004 07:26
To: MX5List
Subject: Re: lumbar - any success?
Chemists, I had a couple of them. They are like a 75-100 mm diameter roll of
medium-soft foam in a cloth outer and worked a treat.
Hope that helps
Janet & Jeff Curtin
Post by Janet & Jeff Curtin » Mon Oct 18, 2004 9:14 am
My wife and I have just got back from doing a 2000km trip around the top
of the south Island, (Is there a better run for a mx5 than the Reefton to
Springs junction saddle road) anyway we both have had the problem of the
crook lower back, so this time we squeezed a small towel in behind the
seat padding and hey presto we both had a pain free trip.
Jeff and Janet.
Colin Francis
Post by Colin Francis » Mon Oct 18, 2004 9:29 am
On Mon, 18 Oct 2004 09:14:16 +1300, you wrote:
I trust you had the top down for most of the trip. :)
Col
http://miata.cardomain.com/memberpage/684887
Janet & Jeff Curtin
Post by Janet & Jeff Curtin » Mon Oct 18, 2004 9:40 am
Yep Colin,except for Arthurs Pass to Jackson heavy rain,and Westport
to Inangahua due to the same. saw a red mx5 at woodend, plate max5, top
down in a southerly squall towing a trailer to the dump LOL, saw a mx5 at
the art centre car park, plate 2 toot, with fantastic chrome exterior
mirrors.
Janet and jeff.
Date: Mon, 18 Oct 2004 09:29:57 +1300
Col
Return to “2004”
