1990 NA 1.6 Inlet Camshaft
Anthug
Post by Anthug » Sat Sep 25, 2004 2:04 pm
Hi All,
I am in the process of rebuilding a replacement cylinder head for my engine
(1990 1.6L).
Just found out the locating dowel pin for the cam gear on the inlet camshaft
has been snapped off.
Does anyone have a spare inlet cam for a 1.6 they want to sell?
Regards,
Anthony.
Jeff
Post by Jeff » Sat Sep 25, 2004 8:58 pm
if you're in Auckland, City Garage has a spare head sitting around at the
moment...
Anthug
Post by Anthug » Sat Sep 25, 2004 10:42 pm
Thanks Jeff, will give them a call on Monday.
Fletch
Post by Fletch » Sun Sep 26, 2004 7:18 am
It shouldn't be that hard to just remove and replace the dowel...
its 5mm diameter, and any engineering supply can give you what you need
(about 5mm diameter and 10-15mm long), I think I payed 50c or $2 ? nearly
nothing.
You could try removal either by applying heat, and then tapping the
cam-shaft with a hammer while the offending end was facing downwards (ie.
shock/gravity)
Or, drill/tap a small hole down the middle of it and extract it with a
screw?
In any case, I think you can solve this problem for way less than the price
of a camshaft or head...
Anthug
Post by Anthug » Mon Sep 27, 2004 9:18 am
Thanks Fletch, great information, had wondered about it being removable.
Shall give it a try.
Anthony.
Return to “2004”
