Standard dial faces
Standard dial faces
Anybody in Christchurch got a standard set of dial faces I can borrow for a
couple of days .. NA model. My signwriter can produce a decent set of white
faces provided he can get the originals to scan. He has patterns for dozens of
old cars and new ones but not the MX5. The quality of his work is brilliant .
Once he has the pattern he charges 70 bucks for a completed set with the colour
of your choice
Colin Francis
Krenford Holdings Ltd
P.O. Box 18547
Christchurch
New Zealand
www.westmorland.co.nz
of your choice
Colin Francis
P.O. Box 18547
Christchurch
New Zealand
Standard dial faces
Didnt you get the white face dial image I sent you ??
Nigel
Nigel
Standard dial faces
On Sat, 28 Aug 2004 09:29:33 +1200, you wrote:
my signwriter needs the positions of the needle holes and odometer cutout etc
as his machine automatically cuts these out . They are also finished on a
plastic and can be back lit in colour . Once he has a pattern he can supply to
club members at a real keen price Nigel. I have seen a lot of the gauge faces he
has made for Rice Boys here and they are excellent.
Someone must have a set of MX5 faces laying around
I don't want to take mine out yet as I use the car every day.
Colin Francis
P.O. Box 18547
Christchurch
New Zealand
Yep . I did . Thanks for that Nigel . The reason i need a standard set is thatDidnt you get the white face dial image I sent you ??
Colin Francis
P.O. Box 18547
Christchurch
New Zealand
Standard dial faces
Wat is your home address and I will post you a set on loan. To scan the
original you need to take the stopper pins off RPM and oil guages which
basicaly buggars them !
I have the ones I used to get my scans.
You also need to work out what you are going to do with the needles as white
on white is not too good for seeing what speed you are doing !!
Nige
Nige
Standard dial faces
On Sat, 28 Aug 2004 10:44:04 +1200, you wrote:
Nigel has graciously come to the party .
Colin Francis
P.O. Box 18547
Christchurch
New Zealand
Looked at that . It has been well raped Biff.Colin,
Have you tried Don, he has that front in his loft??
Biff
Colin Francis
P.O. Box 18547
Christchurch
New Zealand
Standard dial faces
When the gages are up and running any chance of a link to a picture, I
would like a set.
Cheers Jeff.
Listen to music online with the Xtra Broadband Channel !
would like a set.
Cheers Jeff.
Standard dial faces
Ross maybe able to help or Mazspares in CHCH also maybe able to do
something.
Dave
something.
Dave
Standard dial faces
me too!
k
k
Standard dial faces
Colin,
What do you need?
I work for a web development company remember, so if you need anything on
the graphics side I can help.
Biff
What do you need?
Biff
