Hi All, have just put a new set of tyres on the mx5 - now I know what Im going
to write will cause the boy racer- how fast can i get to whatever - how hard
can I corner clique on this list to mutter and splutter - mmm well...
Anyway just got rid of the silly little 185/60r14's that were on it - always
hated the look of the silly little things - tried a couple of sets and ended
up with good honest Christchurch made Firestone F900 185/70r14s (on special
for only 95 each - beat that!) on there. Yeah, I know, wrong size, far too
big, etc, for this sort of car... But to my eye the car now looks right with
well filled wheel arches, it has a much nicer ride and sits a bit higher (does
about 10-20%of its work on gravel roads so this is good). Gears it up a bit
but it still accelerates (mx5's are too low geared in my op anyway) and
corners as well as I want it to. To me my BRG is now a much better car!
(greens best anyway!!!)
Tim.
new tyres on the 5
new tyres on the 5
On Sun, 1 Aug 2004 20:19:13 +1200, you wrote:
Colin Francis
Krenford Holdings Ltd
P.O. Box 18547
Christchurch
New Zealand
www.westmorland.co.nz
Tried them on a wet road yet ?Hi All, have just put a new set of tyres on the mx5 - now I know what Im going to write will cause the boy racer- how fast can i get to whatever - how hard can I corner clique on this list to mutter and splutter - mmm well...
Anyway just got rid of the silly little 185/60r14's that were on it - always hated the look of the silly little things - tried a couple of sets and ended up with good honest Christchurch made Firestone F900 185/70r14s (on special for only 95 each - beat that!) on there. Yeah, I know, wrong size, far too big, etc, for this sort of car... But to my eye the car now looks right with well filled wheel arches, it has a much nicer ride and sits a bit higher (does about 10-20%of its work on gravel roads so this is good). Gears it up a bit but it still accelerates (mx5's are too low geared in my op anyway) and corners as well as I want it to. To me my BRG is now a much better car! (greens best anyway!!!)
Tim.
Colin Francis
P.O. Box 18547
Christchurch
New Zealand
new tyres on the 5
On Sun, 1 Aug 2004 21:36:47 +1200, you wrote:
one that's good in the wet as well as dry .Lets know how they handle in the wet
huh ?
Colin Francis
P.O. Box 18547
Christchurch
New Zealand
Sorry. Didn't mean to imply that . I am looking for a change of tire and wantNo - havent had them out in the wet - dont use the car when its wet reallyTried them on a wet road yet ?
Colin Francis
P.O. Box 18547
Christchurch
New Zealand
anyway. You think that that might be their downfall? Why? Have you tried
this size out on wet roads? Tim.
huh ?
Colin Francis
P.O. Box 18547
Christchurch
New Zealand
new tyres on the 5
Colin Francis
P.O. Box 18547
Christchurch
New Zealand
new tyres on the 5
I dont know this tyre at all, and cannot comment on it specifically...No - havent had them out in the wet - dont use the car when its wet really
But its not the size of a given tyre that affects its wet weather
performance... Its the rubber compound and the tread pattern.
So, tyre model X will be good in the wet, in many if not all sizes, and if
tyre model Y is known to be a poor wet performer in size 1, then its likely
the same in sizes 2,3 and 4 as well...
new tyres on the 5
Colin - as you seem to be in chch the best idea would be go and see Brent at
Firestone in Kaiapoi - he put these tyres (and a some others) on the mx5 for
me to try out with a drive up the motorway and around town before I bought
them, I'm sure he would do the same for you. Tim.
new tyres on the 5
Thanks for your comments Fletch, Ive been very happy with the locally made
Firestones (comfort and wearability) that Ive had on a couple of other 4x4
vehicles but as I say am not one to push tyres and driving to the limits.
I guess sitting the car up a bit higher (with this bigger car size tyre) is
going to make it not so good under hard cornering but for me the other
advantages should outweigh that. Tim.
