soft top catches
Roman Kouzmenko
soft top catches
Post by Roman Kouzmenko » Fri Jul 30, 2004 8:46 am
Hi,
I've recently started to experience problems with my soft top: one of the
'catches' (the two things you use to close the soft top) is out of use (it
won't close, because some plastic on it got damaged.. by frequent use, I
guess). I went to my garage today and they said that this piece would cost
me 250 USD to buy, which seems unreasonably high. Does anyone know a good
place where to buy it online, and the 'official' name of this thing, so
that I can
look it up.
Thanks.
Chic Lynch
soft top catches
Post by Chic Lynch » Sat Jul 31, 2004 11:11 am
I can't think of any plastic piece which would make the latch stop
working, unless you mean the plastic piece which covers the hexagonal
adjustment mechanism. It's on a hinge and it should just clip back into
place. If it's been damaged and doesn't fit back in, I'd try breaking it
off. The latch should work ok without it. The only down side is that you
'might' have to adjust the latch more frequently because the bolt isn't
being held in position, but I doubt it.
Failing that try a wrecker. Ross here in New Zealand will have the part
(www.mx5mart.co.nz) and he ships worldwide, even to Pittsburgh (judging
by your email address)
You could also try
www.finishlineperformance.com
www.Mazmart.com in Atlanta
or ebay
Chic
On Thu, 29 Jul 2004 16:46:50 -0400 (EDT), Roman Kouzmenko wrote:
Hi,
that I can
look it up.
Thanks.
Return to “2004”
