Cam belt
Cam belt
Post by poison » Sun May 23, 2004 11:48 pm
Hi again
Sorry to fill all your mail boxes with so many questions today, the previous
owner of my car had done about 70-80,000km but did not do the cam belt, so I
guess it's well due. Can anyone recommend somewhere in Auckland that's nice
and CHEAP!!! (in fact they don't need to be nice at all :-)
Gazza "PO1SON"
Janet & Jeff Curtin
Cam belt
Post by Janet & Jeff Curtin » Mon May 24, 2004 4:25 pm
Don't know about Auckland but do shop around, I have had quotes from 2 to
5 hours labour"""
Cheers Jeff.
Listen to music online with the Xtra Broadband Channel !
Colin Francis
Cam belt
Post by Colin Francis » Mon May 24, 2004 4:55 pm
On Mon, 24 May 2004 04:25:58 +0000, you wrote:
<html><div style='background-color:'><P>Don't know about Auckland but do shop around, I have had quotes from 2 to 5 hours labour"""<BR><BR>Cheers Jeff.</P><BR><BR><BR>
<P dir=ltr style="MARGIN-RIGHT: 0px" align=left>&nbsp;</P></div><br clear=all><hr>Listen to music online with the <a href="http://g.msn.com/8HMBENNZ/2749??PS=47575">Xtra Broadband Channel</a> !</html>
Any chance of you doing the decent thing and post TEXT emails instead of the
HTML variety ?
Colin Francis
Krenford Holdings Ltd
P.O. Box 18547
Christchurch
New Zealand
www.westmorland.co.nz
Perry perry
Cam belt
Post by Perry perry » Tue May 25, 2004 1:10 am
You may wish to consider other work that may be required to be carried out
at the same time.
As I had my cambelt replaced along with; @115,000 km
1. belt tensioners rollers
2. all the seals
3. all the other belts
4. rad. hoses
5. the water pump as if it failed in the future you still would have to
remove the cambelt to access
the pump.
.. and had the front discs replaced and the seized rear brakes repaired
and bleed.
That costed $1,500!!! major budget blow out. The quote for just the cambelt
only was approx $500.
But at least it was a job well done, and no one complains about good quality
workmanship...
remember... if it's cheap... will they know of the associated problems with
earlier NA models which had camshaft failure as a result the incorrect
manner a certain 'pin' is re inserted the wrong way around?
GrubbyMX
Cam belt
Post by GrubbyMX » Thu May 27, 2004 11:28 pm
While we are at it any chance of you replying with the new text at to top of
the Email string Colin?
Ralph
Keith
Colin Francis
Cam belt
Post by Colin Francis » Fri May 28, 2004 12:21 am
Ralph
I trust you know more about MX5s than you do about email protocol.
They are not email strings. In email groups they are called threads. THe only
reason why many post at the top is because Microsoft have so dictated in their
lame Email clients to do so thus moving away from the Email convention.
Html postings are also frowned upon in most email groups. Security wise it is
not wise to use html either.
Only too happy to educate Ralph. :)
GrubbyMX
Cam belt
Post by GrubbyMX » Fri May 28, 2004 12:28 am
Sorry to be so iggerant colin, I will go back to my box
Isn't a string a thick thread?
Keith
Colin Francis
Cam belt
Post by Colin Francis » Fri May 28, 2004 1:40 am
Ahh. The vagaries of our language. LOL
Col
In a mausoleum colossol,
the explorers uncovered a fossil
that they could tell by the bend,
and the knob on the end,
'twas the peter of Paul the Apostle
Lyndon Pope
Cam belt
Post by Lyndon Pope » Fri May 28, 2004 5:20 pm
I was a Computer Engineer for twenty four years. Started on mainframe about
1978, got out a couple of years back when the little PCs became so
mind-numbingly boring. So I feel suitably qualified to make the following
observation about the text below. 'Strings', 'threads'... who cares!!
Return to “2004”
