Thanks for gr8 tips re closing soft top. It does seem to be largely weather
dependent, although I will get it slightly adjusted.
I was also concerned re the hard suspension at first, but after a week
realised that's the way it is and am now enjoying the feel of the road.
Jeani
thanks
jeff
thanks
you might want to fiddle with the tyre pressure - I
find the recommended 28psi is most comfy, 38 psi is
firm and sporty, 32-34 psi is crash hard and
unbearable. Strange.
This assumed you have the 14" wheels+tyres ... things
get firmer as wheel size increases/tyre sidewall
decreases.
Hope that helps.
cheers,
Jeff
decreases.
Hope that helps.
cheers,
Jeff
