Spare wheel relocation
Hi
Has anyone any eperiences they can relate re moving the spare wheel to under
and MX5 . mainly related to heat from the muffler etc ..
I am located in Ch-Ch. Which Muffler Co is the recommended one to carry out the
work ?
Col
Colin Francis
Krenford Holdings Ltd
P.O. Box 18547
Christchurch
New Zealand
www.westmorland.co.nz
work ?
Col
Colin Francis
P.O. Box 18547
Christchurch
New Zealand
I had mine done here in Blenheim more than a year ago. My car already had an
aftermarket exhaust system on it with a small rear muffler, so all I had to
get done was the rear muffler moved and the pipe relocated to make room. The
original MX5 muffler is too big to do this. A heat shield was fitted to the
muffler as well at the time. This work cost me just less than $100.00 from
memory. It's well worth the effort to probably double the usable boot
capacity!
I can email you photos of mine if you like.
capacity!
I am also interested in shifting my spare... Grant, if you could email me the
pics of your job too I would be most grateful.
Cheers Joan H
Cheers Joan H
Weve done this mod to both of our 5's as well, but included a new muffler
each time. Total cost was $145 each car. No problems with the heat near the
spare either. A thoroughly recommended, if not essential mod.
Subject: Re: Spare wheel relocation
Date: Sun, 25 Jan 2004 13:08:59 +1300
capacity!
capacity!
On Sun, 25 Jan 2004 13:08:59 +1300, you wrote:
Col
I would appreciate your sending me the pictures Grant. Thanks for the offer .I had mine done here in Blenheim more than a year ago. My car already had an
capacity!
Col
I too would like to get this done b4 we travel to Sth
Island.
Can you email me photo?
Thanks,
Mrs Laurie Broomhall
Island.
Thanks,
Grant I would love a photo and a brief not on how it is done if possible.
Cheers,
Dave.
Cheers,
Dave.
I assume you've all seen this? There are pics and instructions
http://www.mx5club.org.nz/maintenance/spare_relocation/
H
H
Thanks for this, zorruno.
I had forgotten this was on the web site.
miata.net has a photographic example which I used to show the guy a Pit Stop
when I had mine relocated.
I had a high flow muffler fitted at the same time which I recommend.
Also, I recommend using threaded rod and bolting this with large washers and a
lock nut inside the boot. I used a 10mm rod. When I went for my WOF they asked
me to put an r-clip through the threaded rod as they thought the nut I had
might vibrate loose.
Hope this helps!
Got a lot more room now, a throaty exhaust with better performance and a lower
centre of gravity at the rear. A worthwhile thing to do!
Ross
Hope this helps!
Ross
Users browsing this forum: No registered users and 85 guests
