Hi
I wonder if someone know where I can find a Wiring diagram for a MX5 on the
net, someone took a liking to my stereo and "borrowed it" so I need to install
a new one and it wold be a lot easier with a diagram.
mine is a 1990 NZ new.
John J
Wiring Diagram?
Wiring Diagram?
JOHN
, TURBO+go fast stripes
Wiring Diagram?
J&S Johansson <senej@> said:
different from this yet. Can't promise this diagram will be located here
forever though.
http://www.mx5club.org.nz/downloads/spe ... diag_2.gif
and for the search engines
Typical stereo wiring diagram schematic picture mazda mx5 miata roadster car
This is a typical diagram for most models. I haven't found one with coloursI wonder if someone know where I can find a Wiring diagram for a MX5 on
the net, someone took a liking to my stereo and "borrowed it" so I need
to install a new one and it wold be a lot easier with a diagram.
forever though.
Wiring Diagram?
I am in Lynfield, Auckland. You are most welcome to have a copy of mine (from
the Haynes manual).
David Moughtin
the Haynes manual).
David Moughtin
Wiring Diagram?
John,
i use the ones here
http://www.madracki.com/miata/wiring.html
has 1990 to 2000 WD
note it says you should not copy, however i normally only need to check
and make notes so they are great for me.
Mike
i use the ones here
has 1990 to 2000 WD
Mike
Users browsing this forum: No registered users and 76 guests
