Please help. I recently bought a Eunos Roadster 1992. Eversince I've had it
the "HEAT" warning light on the dash remains on. I think this means the
catalytic converter is overheating? How can I repair/reset it? Thank you.
"heat" light
"heat" light
Howdy!
We had this a year ago after taking a pothole on a gravel road a little too
fast! It turned out that there was a loose wire to/from the temperature
sensor in the catalytic converter which, when reconnected, fixed the problem.
So check the wiring "down below" before getting stressed - to see if yours is
the same.
There have been previous discussions on this subject, so search the archives
on the website to see what's there.
Good luck
Kate & Michael Cooper
the same.
Good luck
"heat" light
Remove the Cat Converter.had it the "HEAT" warning light on the dash remains on. I think this
means the catalytic converter is overheating? How can I repair/reset
it?
Users browsing this forum: No registered users and 74 guests
