Konis are not for racing!!!
If you want to go racing then buy a set of TEIN
coilovers with 500Lb and 300LB springs.Which will set you back about $4000.
Konis are regarded as the best all round shock for a
mx5. (20,000 members of mx5.net cant be wrong).
The adjustability is there so you can set it to your
liking whether that is soft or hard, The softest
setting on the konis is actually slightly softer than
stock and it means that you can wind up the hardness
as they wear, so your not having to go and buy another
set of $550 dollar shocks,plus fitting and
alignment.Just think what would happen if you bought
non adjustables (which are mostly harder than stock
anyway)then decided they were too hard or made the car
look too high etc, youd be stuck with them.
Loading up the car for that big weekend out???wind up
the back shocks and kiss goodby to bouncing your bum down the road.
KONI's give you choice and quality.
If you want to keep your car, get KONIS!!
Glenn
KONI's are not just for racers!!!!!
