1989 MX5: The sound of running water???
Delich, Martin
Post by Delich, Martin » Wed Aug 27, 2003 2:13 pm
Has anyone experienced the sound of sloshing water in the car while driving.
The carpets are dry but further investigation has revealed the drivers side
"sill" is partially filled with water. The sloshing sound is made when the
water is moving forward to aft in the sill. Once the car is stationary
slight water seepage can be seen from the rear sill jacking point. There
doesn't appear to be any obvious accident damage on the sill itself or
forward or aft of it; everything looks pretty much stock and original.
Any ideas or experiences appreciated.
Cheers.
MD.
____________________________________________________________________
CAUTION - This message may contain privileged and confidential
information intended only for the use of the addressee named above.
If you are not the intended recipient of this message you are hereby
notified that any use, dissemination, distribution or reproduction
of this message is prohibited. If you have received this message in
error please notify Air New Zealand immediately. Any views expressed
in this message are those of the individual sender and may not
necessarily reflect the views of Air New Zealand.
_____________________________________________________________________
For more information on the Air New Zealand Group, visit us online
at http://www.airnewzealand.com
Mathew
Post by Mathew » Wed Aug 27, 2003 2:35 pm
There are drain holes in the sills to allow the water to escape, but these get clogged up over time and need something like a small screwdriver rammed into them to clear them. There is a factory service bulletin on it that you can find on the miata.net site
http://www.miata.net/garage/tsb/s034_94.html
M@
MX5PWR
Post by MX5PWR » Wed Aug 27, 2003 3:00 pm
Also check the drain pipes for the soft top as these can also become blocked causing water to back up and flow into the sills.
The bottom of the drain hose is just in front of the back wheels and has a rubber flange that acts as a valve. The top of the drain pipes are by the softop hinge behind the seats and need to be checked as well.
Return to “2003”
