I'm planning my spare tire relocation.
The exhaust system reroute requires a shorter muffler (silencer) and
the muffler man says that means I need a Resonator earlier in the line
-- about where the catalytic converter is now.
Now, I won't miss the cat -- I've already emptied it of its stuffing
and that created an echo chamber and a noise I really don't like.
But why the resonator? Just the name sounds like more noise to me.
I don't mind a "neat" sounding exhaust and also wouldn't so "no" to a
few more horses... but I don't want to sound like a "boy racer" or have
to put up with a bothersome level of noise and "resonance" in the
cockpit...
Anyone know anything about exhaust systems -- and particularly why the
resonator is needed -- what it does... etc? Suggestions?
Ross Bryon
Ampersand Design
ross@ampersand.co.nz
Tel 64 9 376 1670
Fax 64 9 376 4009
Mob 64 21 376 167
BRG V-Spec 1991 Roadster
Why a Resonator?
Why a Resonator?
A resonator will give a mellower tone, many mufflers sound raspy without a act
or resonator fitted. Still, you might like raspy.
Lou
Lou
Why a Resonator?
Ross Bryon wrote:
Seems a shame to butcher a newish muffler, but the boot is too small on
the NB too.
don't *need* one, but without it you'll
end up too noisy with only one muffler.
When i got the clogged cats done on my `zx, i got magoo's to put some
resonators in there.
The noise level went up just a little. The smell level went down a
whole heap.
Cheers, Rex
Anyone done this on an NB ?I'm planning my spare tire relocation.
the NB too.
They put them there to simulate the effect of the cat. converter. YouThe exhaust system reroute requires a shorter muffler (silencer) and
You're better off with it, than without it.I don't mind a "neat" sounding exhaust and also wouldn't so "no" to a
have to put up with a bothersome level of noise and "resonance" in the
cockpit...
whole heap.
Cheers, Rex
Why a Resonator?
Thanks... I'll go with mellow. Definately!
Why a Resonator?
Hey Ross,
When i bought my 89 mx, ididnt like the factory "tin" noise so i took mine
down and had my exhaust replaced from the front to the back not including
the headers.
Anyway i had the cat removed,and im a little surprised you took the guts
out,im pretty sure those cats are really really bad for you!
Anyway i specifically said i did not want to be a boy racer or have it to
much louder than factory and i also said i would like less tin i also stated
i realised it was a jap 4 cylinder.
Well they fitted a 2 1'4 pipe with a lv resonator(im guessing low volume
perhaps?)
2 1/4 super turbo muffler
and a 3" stainless tip just to look nice, now im really happy with this
system its not to loud ,but is a little more better sounding than the tin i
once had, now ill be honest there may be better systems out there, but this
one is pretty good, all the resonator does is replace the cat and give it a
little deep sound, and i cant hear it in the cockpit with the roof up. with
the roof down its just right, just audible but not over-bearing.
so i suggest go for it,remove the cat, but dont worry about the new exhaust
law ,im not. as long as you go to a good exhaust place they can do a good
job,im in palmy north and i went to Inlet and Exhaust and they were great.
cost me $450 as well, which i thought was reasonable.
I also noticed a little more milage and the engine was better, but this may
have been cause i wanted it to be if you know what i mean.
Good luck,hope that babble was of some help.
Gareth
the headers.
perhaps?)
Gareth
Users browsing this forum: No registered users and 66 guests
