93 1.8L head cc
PeterD
93 1.8L head cc
Post by PeterD » Wed Aug 06, 2003 8:36 pm
Here is a technical one for you. Im building a motor and need to check
the compression ratio. My Burette is broken but it is only a double
check.
Lou are you out there.
PeterD
lou Girardin
93 1.8L head cc
Post by lou Girardin » Thu Aug 07, 2003 8:08 am
In the old days it was the ratio of cylinder swept area divided by combustion
chamber capacity and squish area on the top of the piston. You will need a
burette or similar. Sorry, I can't remember the area formulas. What have you
changed to alter the c/r?
PeterD
93 1.8L head cc
Post by PeterD » Thu Aug 07, 2003 9:33 am
Thanks Lou, I have the calculation but just need to know the volume of
the head chamber.
Recon includes last os pistons and head skim, I just want to check the
figures obtained from the net.
PeterD
lou Girardin
93 1.8L head cc
Post by lou Girardin » Thu Aug 07, 2003 9:47 am
If I was to guess I'd say an increase of .5 to .75 c/r.
Mikkels
93 1.8L head cc
Post by Mikkels » Thu Aug 07, 2003 12:01 pm
You can fill the combustion chamber with water up to level
with the head. Suck the water back out and weigh it. 1gm of
water = 1cc Will work as well as a burette but requires
accurate scales to 0.1 gm or better.
Don
DBM58
93 1.8L head cc
Post by DBM58 » Thu Aug 07, 2003 12:16 pm
If you sucked it out using a graduated pipette you would not need the expensive accurate scales.
David Moughtin
David
peter.dixon
93 1.8L head cc
Post by peter.dixon » Thu Aug 07, 2003 1:09 pm
Great idea David, one problem though. The head is away being ceramic coated and
I would like to do a dummy build on the bottom end this weekend to check
heights etc.
PeterD
Quoting David Moughtin <Davidm@Snackmate.com>:
lou Girardin
93 1.8L head cc
Post by lou Girardin » Thu Aug 07, 2003 2:14 pm
Why are you concerned about c/r, unless the heads been shaved considerably or
the piston crowns are different to stock, an overbore of that size shouldn't
cause you any problems with excessive c/r.
93 1.8L head cc
Post by SLYDIT » Thu Aug 07, 2003 7:02 pm
I thought you couldnt use water to CC a head as it
has a funny skin effect at the very top of the chamber
making it innacurate. Engine builders use an alcohol
type solution instead dont they??? Good excuse to
break out the Vodka bottle from the cupboard!
lou Girardin
93 1.8L head cc
Post by lou Girardin » Fri Aug 08, 2003 8:01 am
You're talking about capillary effect and you're right if you need to
calculate the precise chamber capacity. But if you just want to equalise the
chambers, water would do.
DBM58
93 1.8L head cc
Post by DBM58 » Fri Aug 08, 2003 8:46 am
A good night's sleep is letting me think a little clearer - why even use a graduated pipette when you already have a graduated buerette to measure the volume that you put in in the first place. Isn't that what chemists use when they are carrying out titrations?
David Moughtin
David
Return to “2003”
